Sorry. Forgot I turned off my sig which would have shown the Durango.
And it was an '01 Ram PCM. Just thought to take another look at the link you posted and Ram was still CCD in '01.
IIRC, I thought about swapping in the cluster and column from the '01 Dakota I bought for the 5 spd. swap but it was just different enough it wouldn't work. I'll keep looking for a '00 Dakota quad cab. I'm sure one will pop up sooner or later.
Thanks for the heads-up, Jackie. Been looking for a quad cab for a while now. Not sure I told you about being sideswiped on both sides or if you noticed it when we met up in Commerce. Too expensive to fix, too good a drivetrain to waste, and really miss having a truck also.
Tim
