Jonesy- looks like '01-up is PCI while my '00 Durango is CCD. I would have sworn I bought an '01 Ram manual trans PCM but maybe it was a '00. I'm guessing the PCI & CCD PCMs are not compatible? Truck has a 5.9 and a bad tranny. I thought to swap in the 5 spd. & the manual PCM but may have to buy an '01-up PCM? Hey Jackie, no, it's a blue one w/ a 5.9. There is a silver one up your way with a 4.7. Tim I thought the Durango was the 01 by the thread title. The two are not compatible but you could possibly make it work if you can swap the cluster as well.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
