Pull both flashers. Verify 12 volt battery hot at the 4 way flasher input and keyed 12 volts at the turn signal flasher input. I checked that also before I posted. But now here is the strange part. With the truck running they will flash but it's really slow. I cleaned the body grounds but that didn't change anything. These harnesses have been so hacked up that I don't know what is going on. The front park lamps are on when the key is on but they don't come on with the switch key off.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
