Who do you like using for brake line replacement? I ordered a set from Right Stuff and every single line needed adjusted and modified. The front lines that went under the frame from the distribution block to the flex lines weren't bent wide enough to clear the frame by over an inch (the "U" shaped valley is narrower than the frame is wide by over an inch). Is this par for the course or are they're more accurate companies out there?
It even appears they put the wrong firewall line in the box as it was tagged with a different part #.
