Originally Posted by FC7cuda
Originally Posted by JDMopar
Did you look on the top edge of the bellhousing? scope I had a numbers matching 69 Charger R/T that had the engine and trans vin stamped on the top of the flanges of the motor and transmission. Both the motor, and transmission had the full VIN stamped on them, and they were right next to each other on the flanges.
Similar to what was common in 68? I don't recall seeing any number there, but will confirm again tonight.
As far as any VIN numbers on the block, I will be checking with the owner but will not have answer till January at best.
If that was done in early 69 that would have been a mistake.
