I did notice some light bearing material in my K&P when I was creeping up on 18 psi. So I turned it down for the last race. Assuming it was main bearing material. That's the main reason I pulled caps. As for logs there was zero change in oil pressures throughout the year.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
