Originally Posted by madscientist
Originally Posted by WHITEDART
Originally Posted by BradH
All the additional holes of the Assassin bars are only of benefit if you have a solid baseline from which to tune, as well as the time to test the various configurations. If not, I can see people getting lost among all the possibilities. There's something to be said for keeping the options to a usable minimum.
.. Agreed ..it's like buying a flashy fishing lure..99% of users More adjustment is not needed they have issues in other areas that need to be addressed... A lot of times more adjustability creates more variables and issues from what I have seen
I'm a bit surprised you haven't bent a spring yet as quick as you are in 60 feet.
. Call Calvert tell them what the application and hp level is and they will set you up with the Spring that . Will be trouble free.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
