Originally Posted by TRENDZ
Depending on air temps, I would use anywhere from 0° to -10° to maintain rpm and build boost when staging (turbo). Procharged cars can use timing for smooth power management, and/ or blow off valve actuation for abrupt traction loss.
Timing is more effective with a blower than with a turbo. Reduced timing with a turbo increases exhaust heat, speeding up the wheels in the turbo. That effect is non existent in a procharged car.
Nobody I know uses any kind of boost control with blowers of any kind. It is all done with timing and fuel.
Look for solenoids on BOVs... especially on cars with dual BOVs. We all know how simple a BOV can be used/ plumbed. When you can’t see where the actuator lines go......
Timing is more accurate and much quicker acting. If they get into a position where that's not enough they add a bunch of fuel.
