Originally Posted by RapidRobert
On a side note a BB oils the rockers when the #8 and the #6 cyls are at TDC and a non magnum SB oils the pass rockers at 90 (1/4) turn BTDC #1 compression and the driver side rockers oil at 20 ATDC #6 compression
Thanks RR, I had forgotten the deg where it oils.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
