I used the lighter weight Dynamat on the front floors and tunnel, and the carpet kit already has the 1/2" jute glued to the carpet. I then used the Dyna mat under the rear seat, and 1/2" thick Boom Mat over it, glued with 3M Spray contact cement.
It is very quiet, and deduces the heat from the mufflers.
