Originally Posted by Cab_Burge
Originally Posted by SportF
Cut the baffles out and use the factory covers. 640 lift rollers on this.
iagree scope
I've also dented the baffles as well as drilled holes with a small hole saw in the baffles above the adjusters to make them not hit, lots of choices, you choose up scope
Let us know your choice and results, that will help others on here later with the same porblem thumbs wrench
iagree Easy fix!
