Basically, where the engines power curve at wot intersects with the pumps load curve....... that will be the terminal rpm....... which may or may not be where the motor makes peak power.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
