Hello Dwayne what's your thoughts about the RPM heads on a 470 motor wanting to run 10's in a 67 Plymouth b- body
In a “race car” you could probably get there with ootb heads if the rest of the car was extremely well sorted out.
In a street car, I don’t see it playing out that way. And if you have to pay for some head work and parts upgrades...... the TF240’s will end up costing the same, or possibly even be less.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
