Ok guys I need help , I have a 46rh 2 wire trans, so will a non lockup converter around a 2400 stall work with the overdrive . Engine is a la 360 . Running this converter in a 727 now . What else would I need to do this conversion as far as vacuum switches or just install a switch to engage the overdrive . Thanks in advance
it should work just fine, if its a good converter, I have a switch on my console for the OD
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
