I use a stock type PCV valve in my 493 and it works great. I don't remember what it is listed for as I have a few around the garage and ended up using this one because it works fine on my combo. I have a good idle and the eng pull's enough vacuum at part throttle that the valve works good. I have been running this PCV valve for about 8 years. Ron
