Have you committed to what cylinder head? And if so, which one?
If you're committed to both factory original iron head, and decent performance, I cannot overstate the need for really good cylinder head work, which is usually not real budget friendly. Consider someone like Dwayne at Porter Racing Heads (PRH).
Also, piston choice should only be finalized after you've committed to the head, IMO.
