I learned somthing interesting about TA valve bodies the other day....They are typically only set at 120psi of pressure while many of the others are set at 200psi.....Also, when I ran a 904, it would always burn high gear due to lack of oil....You have to run a nice deep pan with one of those to live.....My 2-cents worth.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
