Originally Posted by Cab_Burge
What valve body are you running?
I don't like low band apply manual valve body for that reason work
Stock valve body.. I want to upgrade to a non LBA valve body soon.. I really cat explain why I pulled the shifter into low instead of high.. just a dunce move. confused
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
