40 years? That 340 is most likely not going to turn over. Even if it did there will be valves stuck open and the pistons will hit them. Plan on a full rebuild. Pull the heads, soak the pistons with Kroil, let set for a couple days, soak again and maybe they'll come loose.
I love the smell of Deer guts in the morning, it smells like... VICTORY!
