Sitting in that kind of environment ,. At the very minimum I would pull the heads and oil pan to take a look.
I opened up a 440 that had been sitting in the car for about 15 years and found all kinds of surface rust in the bores. It was inside a dry garage with concrete floors . Never tried to turn it over, owner said pull it and go thru it.
