Originally Posted by Chip
First race weekend eva at 58 years old in my 1970 Barracuda with a 440 stroked to 500-inch...check mark in the bucket list cool
Ran a best 10.72 but was letting up...testing, newbe, and car was hitting the rev limit. I had a 7000 module limit in my MSD 7AL-3.
Car weighs 3150 with me in it, has a 430 Dana rear, 3 speed 727, 31x15 big tire...i know there is more in it. Max torque 653 @ 5500-rpm and max hp 766 @ 6600rpm
How high to you guys rev your big blocks?
It really depends on what head is on your engine. However, if you made 766 @ 6600, id bet shifting at 6800-7000 and going thru the stripe at 7000 would work well. You may want to re think your gearing. 3.70? might work better.
Any case if you made your most power at 6600, going much past it is not going to help, even if the engine has light weight components that can rpm higher.(steel or alum rod)
....BAD A$$ STREET CAR.....
