Originally Posted by I_bleed_MOPAR
Originally Posted by kenworth_goose
I've done the swap a few times. I use truck brackets and mounts and fab a box on each side of the frame and I always move the engine and trans. back to the firewall. They actually handle much better when you move the engine back. If I remember right it's 2 1/2 inches back. I use 3/16 plate to make the boxes for the mounts. I put slots in them just like the trucks. It;s a very easy job if you can weld.
Now, that's what I was looking for. up
Thanks, k w g. beer
Tim
You are welcome!
