I have built a T/A transmission and there is really nothing different than other A833 transmissions. The 70 trans you have is probably correct unless somebody installed the better ball-detent cover instead of the lever type cover in your picture. If you aren't building a total resto that is going to be judged the ball-detent side cover works better IMHO twocents
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
