Hello
Just got a '77 W-200 truck for cheap. It is missing the upper part of the kick-down linkage. The bellcrank on the intake is there. The Edelbrock carb needs a part on the throttle lever to attach the missing linkage to.
Can you see exactly what is missing? A photo of the evaquation would help a lot😀
Attached is a picture showing the situation as it is now.
