I have to agree, if I had it to do over again, I'd go with the Bouchillon setup.
That said, the Lokar setup works quite tidily with my AR Engineering tall throttle bracket. The Bouchillon setup is not quite so elegant, but is far more robust. My setup works quite well as customized.
