516, 906, 452 heads don’t have similar enough port shapes to be able to use the same program for all 3.
If one were to try it, they’d likely end up with holes in the head.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
