Originally Posted by roe
Sorry for the long hiatus. I decided to just have the shop (TX) look at. I'm not sure of the details but they did determine they made a mistake and it needed a teardown for diagnostics and repair. I didnt have enough time for them to do the job since I was moving out of state so they covered the cost for a shop here in WI to do a rebuild. When the car is finished I will ask about the details and let you guys know where the problem was.
Well at least we know you are still alive!
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
