yes--the input lengths are different------if you have the early chev you cannot fit the dodge inputs because the gears dont match up-------to change the early chevy you have to totally disassemble the gear case to get to the gear the input touches----if its the later you can change the inputs by taking out the 4 bolts on the bearing retainer (throwout bearing) then just pull the input out---there are pictures of it on the internet....
