Just use the thrust block for the limited slip and you can use an open diffs thrust block with a spool. Adjust the end play as per manual and No need to change to green bearings.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
