Also, I would like to get some type of interlocking motor mount for the driver side. I assume you have a change of breaking the exhaust manifold if the engine moved more than an inch or so. It looks like the standard motor mount with a-body specific brackets?
I also will need to replace the battery tray. Goodmark, Sherman, AMD or find an original?
