You bet Wally, I'm glad that new Gas Pot is working out for you.
Are the firestones still on it or are the cords showing on them?
The only thing that can be done is electric fan (if it doesn't have one already) to free up 4 or 5 hp.
The biggest thing you can do is whack the catalytic convertors out (about 25hp), but, unfortunately, no way to get into the factory computer to shut the downstream O2 sensor off so, it can't be done: You'll have check engine light forever, and if I'm not mistaken, some of this new stuff will actually de-rate the hp.
