Try adding some air(.5 to maybe 2.0 Lbs.) to the rear tires to see if it will make the car 60 Ft. quicker instead of jerking the front end up so high scope twocents
If that doesn't help try slowing the front end travel down some, make it stiffer on the extension wrench
