Pretty sure the way the ignition wires were cut through that this furry little guy bit through two ignition wires, the upstream O2 sensor and what I'm trying to figure out what else. This is my wife's '01 Town and Country Limited with the 3.8 V6. Any help would be greatly appreciated.
The O2 sensor connection is behind this connection on the driver's side "frame rail" topside, and it has four wires, two White, a Black single and Gray single wire. Also there is another item that if I were guessing I would think it looks like a speedometer pickup sensor but not sure, it was just hanging there near the O2 sensor connection. I disconnected the O2 sensor not the groundhog, it just chewed through the wires of the sensor and whatever the four wires were connected to?
Thanks in advance.
Mike
