Since 1963, maybe earlier, Mopar B body have had two different wheel bases, the Plymouth are usually two inches shorter wheel base than the Dodges are The K members and most of the front and rear suspension parts are the same so where do you think the extra two inches occurs between As already pointed out, don't do that
That is what I have always thought, did John have this backwards?
