Originally Posted by 72 RR DUDE
Ok so i just found the problem. When i took the accelerator pump off the check wall and little brass strip that holds the ball in place fell out. The only thing i don,t know is how to keep the brass piece in place. Anybody no????
Well...... you found “a” problem...... but that doesn’t really explain the empty float bowl and not staying running below 2000.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
