Great info guys! Thanks
E bodies have a separate stainless "drip rail" that screws to the roof. THEN the galvanized weatherstrip channel. So there is 2 layers of sealing strips required.
71-74 B bodies are obviously different.
Thank you. Thank you. The pictures are definitely worth a thousand words.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
