Tire rack shows a Cooper radial in that size as 29"
That's much taller than what I ran with only a little smaller gear (3.23) and TurboAction 3800 (3000 brake stall).
But with the four speed the gearing might work out OK.
Tallest tire I ran was just over 26". usual street tires were (and are) 25.5" dia.
Quickest time and best mph at the track was on 24" (225/50r15 Yok 008 which was an autocross-roadrace tire)
13.77 99.5 through manifolds and full exhaust. With better traction and gearing it you can go quicker than that.
