The drop base air cleaner that was fine on the Holley DP hangs up on either the choke assembly or the fuel inlet of my new AVS2. Can't remember which. So I run a plastic 1/2" spacer ring. It's kind of a PITA, but gets the job done and I have enough room under the hood for it and I'm too cheap to buy another base or assembly that fits.
