First thing that stuck out to me was, IMO, there is no reason for the engine with that camshaft to idle at 1200+ in P/N.
That engine should easily idle at 950 and a pull down to 850-900 in gear if the converter is OK. Might be a ground up issue to some extent, too much plate opening at idle.
