The weights being free to move will not matter if the advance mechanism is jammed/locked. With the unit installed or the shaft being held, you should be able to turn the rotor/reluctor assembly to some degree (1/4"-3/8") and have it be pulled back to the base location by the springs. Obviously, the unit with the heavy springs will require more effort to turn, but neither should require a lot of effort to move.
If the results don't match the theory, change the theory.
