Originally Posted by General 68
Thanks! Keep it coming😄
I just ordered the 232/236-110 Hughes cam. Quite exited to ser how it performs.
This is a mild build, 505,cr 9,8:1, Stage 4 iron heads, Indy dual plane, 2" tti's, 3" x-pipe, Holley 850 dp.
4200 lb '68 Charger, Tko 600 5-speed, Dana/Moser 60.
I have an opinion on how it will perform, but what are your opinion?
It will be a handful on the street, small cam for a 512
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
