If you are going to drag this car and since the car is inherently light from the factory anyway, it is best that you leave the rear window just as it is for some weight assistance in that department.
I'd leave it alone and concentrate on the front shield and side glass.
Fullmetal
Car is used on street but is not really a go somewhere car. More of a hot rod with blower setup on it. No interior and partial cage with engine moved back and rearend moved forward in it. Plus have a sub section on the rear tied into the front at the door hinge area with square tubing. Current setup is at 3740 pounds. So this is why figured while I am at it doing some body work on it and front window is pitted. Maybe change everything and get lighter.
