I just read the following in forkbook and am curious about the accuracy of the following.
“ Organisol was used on the front of all Mopar radiator supports, not just the trucks. It was sprayed from a pit, below the assembly line, therefore not getting on the top of the support.
It was also used on the tail panels of Hemi Cudas, the hoods of Super Bees and it is a semi, or satin black finish.”
I thought they were semi to flat black...?
Thank you
Red
