That's the main reason I pulled out my brand new 4 speed carpet on my never driven yet 4 speed E-body and bought carpet from ECS. NO comparison on fit between the two.
ECS's carpet is made by ACC by the way...the OP stated he was "told" his carpet was ACC, not defending ACC if that is their carpet?, but I agree the fit is horrible
I know from past ordering experience with Legendary that you have to emphatically specify you want ACC carpet or you will get a substitute ...
I would suggest the OP order DIRECTLY from ACC, and also specify the Mass Backing be applied to his replacement carpet...the ACC carpet in my 70 Charger was a perfect fit front to rear, side to side, as well as fitting all the floor contours
