Cut the mounting tab off the old one and install it over the existing mounting, under the same screw, connect the cluster ground. Or replace the spade connector on the ground wire, install a ring terminal, install it under the mounting screw. Would not recommend just leaving it disconnected, there is reason the ground wire exists.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
