Originally Posted by AndyF
Originally Posted by Stanton
There has to be a lower bearing of some sort !!
Not in the early floor shift columns. There might be something in the column shift setup. The floor shift column has a rubber and nylon type of seal arrangement at the bottom but not a bearing. Here are the two columns I'm working with. I need to convert my red column over to PS from manual steer so I'm parting out the blue column and putting the parts in my red column.
So the longer shaft is for the manual box?
“So if it’s on the internet it must be true”
Abe Lincoln
