Thanks for the replies guys. I fussed with it some more this weekend, and I can see now mounting the outer on the outside would make a mess. I believe this outer is just made wrong. The lower front where it attaches to the rocker is an inch or better forward and that's keeping the front radius flange an inch or 2 behind were it should be. Also the rear line up hole visible through the trunk is about an inch low. When those holes are lined up it makes the wheel house too high in the back. Again the new AMD inner wheel house fits perfect. The line up holes line up and there is room for adjusting it for a perfect fit. I'm going to call AMD and see if they will help. I think it's as simple as pulling an inner and outer and seeing if they fit together. I've spent $4-5000 on AMD sheet metal so far and I think they should. And Demon since you've installed some that did fit, hopefully there are some that will. Thanks again!
