So how do I remove the horn ring from a 1965 Dodge Coronet 500 steering wheel? My FSM doesn't have a steering column section in it. I have newer FSMs but I'm not sure the directions are the same. The '67 manual says to twist the horn ring CCW to remove but that doesn't seem to work with my '65.
