as dayclona said, those tires are [to be Very kind] NOT round.
however, that tire is no worse than they were back in the day. i always wondered about that because some tires like that balanced to where you couldn't feel them, and others would hop all over the place.
and if you think those are bad, you should have seen some of the ReCaps that were done at the same shop i worked at. [those ReCaps had the reputation of being the BEST in the area ! go figure.]
beer
