I agree that the backside would tell. To me, on my ipad, they look like a unilug oval. I’m not a fan, but if that’s the case then the damage on the other side doesn’t add to the issue once mag lugs and washers are used.
If however they are NOT unilug, then they are damaged beyond use.
Being hub centric, the center hub positions the wheel, not the lugs, so the wheel is not "damaged beyond use" if the correct lugs and washers are used, even if the lug holes were "ovaled" out from improper prior hardware ....
